TF 3" kit in!! extended abs lines?
Got my disco back tonight, with the 3" terrafirma kit installed and ebc rotors/pads.
i have the extended brake lines, but anyone know where i can find extensions for the abs wires? they seem pretty tight now, but i cant find any listings on atlantic or lucky8?
on
You most likely won't need ABS extensions, just need to re-route the ABS lines so they stretch further.
Curious, what size tire you are running? Also would you take a couple minutes and go measure the height of your front and rear by measuring from the ground thru the center of the tire to the bottom of the wheel well molding, I am just curious, Thanks
haha second person that said that
as soon as I get home I'll pic it up.
sure, DMike, I actually took a bunch of measurements BEFORE the lift so I'd have some comparisons.
I didn't get tires yet, I'm still running the factory. Looks silly, but I wanted to see exactly how much room I had to play with.
I didn't get a chance too look at them myself yet, i picked the truck up after work and it was already dark... but the mechanic just mentioned it on the phone that the abs wires are getting tight and he recommended longer ones... that and my wheel seals in the back are leaking apparently
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
![Frown](https://landroverforums.com/forum/images/smilies/udbMv2o.png)
ebg18t
08-20-2013 05:16 AM
