TF 3" kit in!! extended abs lines?
Old Nov 9, 2011 | 07:28 PM
grandkodiak's Avatar
Default TF 3" kit in!! extended abs lines?
Got my disco back tonight, with the 3" terrafirma kit installed and ebc rotors/pads.
i have the extended brake lines, but anyone know where i can find extensions for the abs wires? they seem pretty tight now, but i cant find any listings on atlantic or lucky8?
Old Nov 10, 2011 | 09:40 AM
You most likely won't need ABS extensions, just need to re-route the ABS lines so they stretch further.
Curious, what size tire you are running? Also would you take a couple minutes and go measure the height of your front and rear by measuring from the ground thru the center of the tire to the bottom of the wheel well molding, I am just curious, Thanks
Old Nov 10, 2011 | 11:01 AM
yloDiscoII's Avatar
Originally Posted by grandkodiak
Got my disco back tonight, with the 3" terrafirma kit installed....
Pics, or it didn't happen
Old Nov 10, 2011 | 01:03 PM
haha second person that said that as soon as I get home I'll pic it up.
sure, DMike, I actually took a bunch of measurements BEFORE the lift so I'd have some comparisons.
I didn't get tires yet, I'm still running the factory. Looks silly, but I wanted to see exactly how much room I had to play with.
I didn't get a chance too look at them myself yet, i picked the truck up after work and it was already dark... but the mechanic just mentioned it on the phone that the abs wires are getting tight and he recommended longer ones... that and my wheel seals in the back are leaking apparently
Old Nov 10, 2011 | 01:45 PM
Emperor_MA's Avatar
235/85-16!!!!
jycsalas
May 23, 2019 03:02 PM
ebg18t
Aug 20, 2013 05:16 AM
ZGPhoto
Apr 19, 2013 01:51 PM
jmason
Mar 12, 2013 08:08 PM
markroll
Mar 19, 2008 10:04 PM
