Is there a ABS scanner like this ?
Old Aug 24, 2013 | 04:09 PM
Externet's Avatar
Question Is there a ABS scanner like this ?
Hi.
These gadgets talk to laptops and smart phones...
Amazon.com: V1.5 Super Mini ELM327 Bluetooth OBD2 OBD-II CAN-BUS Diagnostic Scanner Tool: Everything Else Amazon.com: V1.5 Super Mini ELM327 Bluetooth OBD2 OBD-II CAN-BUS Diagnostic Scanner Tool: Everything Else
Is there one proven to work with Disco SLABS, not the Amigo/Centech/Autel ?
Old Aug 24, 2013 | 04:16 PM
acg's Avatar
acg
The ELM327 is simply an Bluetooth interface unit which sends to the OBDII data to a Bluetooth-enabled unit such as a smart phone.
You will still need to have an app such as the Torque Pro (only available on Android) to display the OBDII data and codes:
Torque — OBD2 Performance and Diagnostics for your Vehicle
I have not had the 3 Amigos issue yet. Therefore, I cannot confirm if the Torque Pro app which I am using can be used to clear the 3 Amigos error codes.
Old Aug 24, 2013 | 09:35 PM
ralphobell's Avatar
I am not aware of any Apps that will read ABS on the Disco using the ELM327
Old Aug 25, 2013 | 08:41 AM
Externet's Avatar
acg: Please come back whenever you find out if reads/clears ABS.
You should not need to have the three amigos active in order to see on your Torque screen, the option to access the ABS data; would show 'no errors pending ?'
lipadj46
Apr 13, 2017 04:51 PM
FlyingZebra34
Oct 31, 2012 09:17 AM
ShortTom
May 21, 2012 10:45 AM
StormTroopa
Nov 28, 2009 06:45 AM
