Is there supposed to be an open hole in the transfer case?
Old Jun 23, 2011 | 10:17 AM
FFJ's Avatar
FFJ
3rd Gear
Default Is there supposed to be an open hole in the transfer case?
New owner trying to learn about my 1999.5/2000 DII.
Had the transmission temp light erradically lighting up so I went under to clean the sensor connections. (this did not help) so I am assuming I may have to replace them.
while under checking around noticed oil leaks from back of engine block and apparent transfer case leak.
also noticed this open hole into the transfer case. is this normal? seams like it should be seal so water/dirt etc does not get in there??
also noticed a bolt that is half out.. Ideas?? Do I need to take action on these?
Attached Thumbnails Is there supposed to be an open hole in the transfer case?-img_1654.jpg   Is there supposed to be an open hole in the transfer case?-img_1656.jpg
Old Jun 23, 2011 | 10:36 AM
DarylJ's Avatar
That's not even anywhere close to your transfer case.
That is the bell housing (behind), and those holes are there in your oil pan so you can get at the torque converter bolts when removing the motor or transmission. They are supposed to have rubber plugs in them.
Old Jun 23, 2011 | 10:38 AM
drowssap's Avatar
if i remember correctly; I think there are rubber plugs that go in the big holes one on each side, and it is use to gain access to a bolt.
The bolt mates your engine to the bellhousing I'm assuming it is not loose, someone probably gauld it putting it in and left it that way, you should try and get it out and replace it. It is quite common when you use steel bolts into aluminum threads that is what antisieze is for. If it wont come out or tighten leave it be.
Old Jun 23, 2011 | 10:45 AM
FFJ's Avatar
FFJ
3rd Gear
Ok thanks for the advice! Where can I purchase the rubber plugs from? They are indeed missing from both driver and passenger side of the bell housing. Atlantic british or another place??
Old Jun 23, 2011 | 10:52 AM
FFJ's Avatar
FFJ
3rd Gear
Nevermind- Found it. Part#ERR7229.
thanks for getting me in the right direction guys!
Old Nov 11, 2015 | 11:24 AM
DII_Noob's Avatar
3rd Gear
Curious if you got the Rubber Grommets in and if they were ok to install?
My old ones are so old, swollen/expanded from oil saturation, etc...they would never dream of getting back in place without shrinking them in the dryer...
Just wondering if brand new fit better?
Old Nov 11, 2015 | 11:53 AM
Paul Grant's Avatar
Google is your friend.
A search of ERR7229 turned up a listing from one of our sponsors:
Land Rover Parts, Accessories and Information
clint70
May 27, 2015 11:17 AM
audiS4S6
May 6, 2010 12:14 PM
StormTroopa
Nov 28, 2009 06:45 AM
