Thermostat bypass thingee,,,
Old 03-21-2019 | 10:00 PM
HuskerRover's Avatar
Default Thermostat bypass thingee,,,
I tried searching but came up with thins of "other" threads. Will someone link it for me please?
Old 03-22-2019 | 03:14 AM
JUKE179r's Avatar
Google "Discovery thermostat mod" for forum postings and pics...
Originally Posted by bguetter
Finished up installing an inline thermostat last night and got a chance to put about 50 miles on the setup this morning. I'm using a 180* thermostat and driving in 90*+ weather today my temps ranged from 177-185. 185 was only after sitting at idle for 5 minutes and then stop and go through construction zone.
Hardest part of the install was getting the old factory hose clamps off. I had to modify the fan shroud slightly to allow the thermostat housing to sit a little lower and not hit the hood.
parts needed-
Meizere inline thermostat housing
chevy v8 thermostat
lower radiator hose off a 2002 bmw 330
some type of bleeder valve in top hose, i used a 32mm from Glowshift
I went ahead and bought a new upper radiator hose and cut where needed to fit. I also replaced the brittle plastic tubes with 5/16th heater hose.
It gets up to temperature and out of closed loop fine. Fuel mileage was the same today according to scangauge. heater works fine too.
Old 03-22-2019 | 04:54 AM
GCBurke's Avatar
Old 03-22-2019 | 07:02 AM
Thanks for the assist!
Old 03-22-2019 | 10:52 AM
bcurtman's Avatar
My setup works quite well, but as I said, get 1-1/4" stuff, not 1-1/2".
Old 03-22-2019 | 09:25 PM
Alex_M's Avatar
There's a good amount of info here that should get you where you need to go. If you plan on doing a new radiator at the same time, there's no time like the present to upgrade.
https://landroverforums.com/forum/discovery-ii-18/ultimate-cooling-system%3B-complete-system-upgrade-87611/
DISCOFETA
02-19-2019 03:16 PM
Davis31052
01-14-2019 05:55 PM
escott16
01-06-2019 06:59 PM
abran
03-16-2015 07:28 AM
silar
05-26-2013 10:18 AM
Quick Reply: Thermostat bypass thingee,,,
