Thermostat set at 180
Old Dec 23, 2025 | 05:26 AM
Javi's Avatar
5th Gear
Default Thermostat set at 180
Today’s the first time I saw temp shoot up to 240 for a few seconds and immediately went down. Is this normal to happen?
Idling it occasionally climbs to 200 and then drops down.
Old Dec 23, 2025 | 06:27 AM
Extinct's Avatar
What type of thermostat, inline or oem style?
Old Dec 23, 2025 | 06:30 AM
Javi's Avatar
5th Gear
inline
Old Dec 23, 2025 | 10:53 AM
Extinct's Avatar
Originally Posted by Javi
inline
it sounds like you have a thermostat element without a bleed hole, check that and report back.
Old Jan 2, 2026 | 06:53 PM
Javi's Avatar
5th Gear
sorry for late response. It does have a bleeder hole on top.
Would cold temps cause the high temp spikes?
Old Jan 3, 2026 | 05:31 AM
Extinct's Avatar
No, it shouldn't. If it happens consistently you might have a failing element, that or a failing sensor. Suggest you pull the element and run it a week like that.
Old Jan 3, 2026 | 09:15 AM
nashvegas's Avatar
240? You have a bad thermostat.
Old Jan 3, 2026 | 04:25 PM
Extinct's Avatar
There was a recent poster on Facebook who had a bad sensor, I have had one as well. They start acting flaky. Check it with an IR gun. I keep a pen ir thermometer in the console so I can check actual temps if I ever get an excursion.
Old Jan 8, 2026 | 06:31 PM
nashvegas's Avatar
Interesting, meaning the temp is OK but the reading is bad on Nanocom? Definitely possible. Yes !
Old Jan 9, 2026 | 03:42 AM
Javi's Avatar
5th Gear
I will be order a new thermostat and replacing it. Hopefully that is the issue. Car idles at 180 and slightly below. The heat spike happens quickly but drops right away. Hoping nothing major.
Sherlock
May 22, 2023 10:18 AM
keninnc
May 11, 2023 06:16 PM
flyingmada
Apr 26, 2018 06:42 PM
huggi
Oct 12, 2016 11:09 AM
