thinking frames and ace again.
Would be very interesting to see the differences in handling and offroad capability between two D2's. Both stock. One with ACE and SLS and the other without. I'd like to see them both perform the 35mph corner test. High speed stop test. and general offroading. lt would also be interesting to see the ACE in action up close, by fitting a camera below the truck on the frame.
ZGPhoto: I respect your views a lot and look up to you, but I have to ask... have you ever driven a ACE Disco? Have you ever tested a Disco with ACE and SLS offroad? I have not, which is why I'm not quick to overestimate the potential of those features. All I can say is that LR claims both features improve on and offroad capabilities. Of course the potential of these features can be easily overshadowed when you add lifts, over sized tires, lockers and start tearing out suspension componets. For the sack of a stock D2, is it safe to say these features improve the vehicles performance capabilities? Be it so long as the systems are properly maintained like they should be.
Seems to be a misunderstanding or lack of information about the purpose of the ACE and SLS systems and honestly I think members here have a right to know the truth, not peoples biased views.
Antichrist: the question is can a older D2 frame fit on a 2004 D2 shell without modifying? A clean swap. Is there any variations in the frame from year to year (1999-2004) that would create issues with the swap? If I've asked this question before then I'm sorry. Perhaps I just don't remember you giving me a honest answer about honest question.
On a normal setup the end links are attached to the same bar.
Take a paper clip and bend in the shape of a sway bar (I______I) . simulate atriculation. Do you see how the bar resists articulation? When both wheels are at the same level of compression/extension, the stock bar sees no load. When they are uneven it sees load.
Also, the transmission is longer in 03-04 so the transfer case is pushed back a little. I'm not sure if this cause something to change on the frame either.
Those are at least two possibilities.
^both
There is one arm and then the rest of the sway bar, which acts as the other arm. So essentially there are two...a short arm and a very long arm. The actuator sits where the two come together.
I had a customer buy two clean frames from me this summer. One was from an '02 and the other was from an '03. The customer was a former tech at Land Rover. He was plannning on using them on a couple of '03's he had. He seemed to be under the assumption that there wasn't any difference that would make the '02 chassis incompatible with his '03 shell. Never heard back from him so I have to assume the early frame worked with the later shell.
