Thinking Zip ties to mount my new 8.5mm magnecor wires...thoughts?
Old Feb 11, 2010 | 01:26 PM
elboy0712's Avatar
Default Thinking Zip ties to mount my new 8.5mm magnecor wires...thoughts?
think this will be fine or heat will be a problem. Ive used zip ties all over engine bays before but not that close to the block and manifold
Old Feb 11, 2010 | 02:06 PM
AK Rover's Avatar
Why not use the original wire holders? The 8mm will fit in them it just takes a little more force than the smaller 7mm that the truck came with.
Old Feb 11, 2010 | 02:07 PM
elboy0712's Avatar
Default ill give it a try
but the 8.5mm that i have look probably at least 50% bigger.... maybe ill mount them in then zip tie in for good measure
Old Feb 11, 2010 | 02:19 PM
AK Rover's Avatar
I missed that they were 8.5mm. Where did you find 8.5mm wires? I used 8mm Magnecor wires on my 97 and loved them.
Old Feb 11, 2010 | 02:22 PM
BajaXJ92's Avatar
I've got the 8mm Magnecors as well and I just ziptied them to the original wire holders. Works great just don't let them get too close to the manifold!
Old Feb 11, 2010 | 02:33 PM
hilltoppersx's Avatar
the 8.5's are too big and dont fit in the stock holders, i would use small hose clips instead of zip ties to prevent possible melting.
Old Feb 11, 2010 | 02:51 PM
elboy0712's Avatar
Default good call
i think ill zip tie up for the morning and stop by the plumbing section... then screw the clamps into the original mounting points before bundling and locking it all down.... thanks for the tip
CUpgt
Jan 31, 2014 09:02 AM
Draayer
Jun 21, 2011 07:33 PM
caleb
Nov 28, 2009 06:49 AM
03DiscoSE
Oct 20, 2008 08:45 AM
tee51397
Jan 11, 2008 08:34 PM
