Would some 8.5mm MSD plug wires work?
Old Jun 21, 2011 | 06:24 PM
Draayer's Avatar
Default Would some 8.5mm MSD plug wires work?
I was going to order some new spark plug wires for the 2000 Disco II but noticed in storage I have some new MSD 8.5mm wires that didn't work for a different project. If these are the correct length, and the heads work, (they are 90 degrees on one side and a bit less than 90 of the other side) would they work for the rover?
Thanks,
Old Jun 21, 2011 | 06:33 PM
DarylJ's Avatar
Doubtful. The coil side is almost definitely different unless your other project was something using very similar coil packs.
Old Jun 21, 2011 | 07:33 PM
Wolf's Avatar
The coil packs on a rover tend to vary slightly. I would suggest ordering a new set whether its a stock wire or hi performance. Never second guess with Rover parts, it could cost you a lot of time in the long run.
CUpgt
Jan 31, 2014 09:02 AM
CUpgt
Sep 23, 2013 07:35 PM
elboy0712
Feb 11, 2010 02:51 PM
caleb
Nov 28, 2009 06:49 AM
tee51397
Jan 11, 2008 08:34 PM
