Third row seat conversion Disco II
Old Jul 26, 2009 | 11:24 PM
SBLenger's Avatar
6th Gear
Default Third row seat conversion Disco II
I have a 2000 Disco II that did not come with 3rd row jump seats but I would like to install them. Does anyone know if this is a simple DIY conversion and what would be involved in the retrofit?
Old Jul 27, 2009 | 03:21 AM
Frank4's Avatar
you could probably find the seats from a part out which are pretty common but fitting them would be a pain if not impossible. I had a 99 with the jump seats and found that they were not really functional if you were over 4 feet tall. they were a great fit for my 4 niece. maybe find one with the seats and take a seat and see if it would be worth the time, probably huge expense and total loss of cargo room.
Old Jul 27, 2009 | 04:48 AM
Urban Panzer's Avatar
It can be done pretty easy, but you have to make sure you get the seats, the side trims, floor carpet, head rests, floor fittings / seatbelts etc and ALL the mounting hardware out of scrap / part vehicle.
Not sure on the expense over there, but unless you NEED them, I personally would not bother to be honest. Also bear in mind if you have coils on the back, you will need to uprate the rear springs as well, if you have SLS , then no probs
Old Jul 27, 2009 | 07:03 AM
If you really want/need the 3rd row it is best to buy a 7 passenger model then, you are looking at $1000+ in parts then labor on top of that.
And the labor is going to be huge becasue you need to cut up your floor to install the seat latches and your roof to install the headrests.
Old Aug 1, 2009 | 03:07 PM
SBLenger's Avatar
6th Gear
Thanks all for your input. I'd want to convert mine to 7 passenger for occasional use when we have friends' kids visiting and need to haul the herd around.
I've found parts at dismantlers pretty reasonably priced - I'm just concerned about doing this as a DIY project. Is the blocking / brackets in place under the trim to install the floor brackets, seatbelts, headrests, etc. or am I looking at major surgery beyond replacing or cutting trim?
Old Aug 1, 2009 | 04:43 PM
You are looking at major surgery, to much work for it to only be used half a dozen times a year IMO.
Most people get the whole floor from the donor vehicle and then cut out their floor and weld in the "new" one.
Old Aug 12, 2009 | 02:54 PM
gnomeboythree's Avatar
7th Gear
I think I'm a little late to the party here, but I also have a 2000 Disco II and am (was) looking to find a way to do an SE7 jump seat conversion. I spoke with Jim (Biggs LR) and he told me that it would be an extremely difficult undertaking (welding, cutting, swearing, etc.); at that point I asked him if a Disco I jump seat (side facing) could be retrofitted. All I'm looking for is to put in one such seat and still maintain one of the stock SE storage bins. Does anyone know about Disco I to Disco II jump seat conversions? Thanks guys!
Old Aug 12, 2009 | 04:24 PM
Wont look good because the DII is longer than a DI.
The wheel base is the same but the stance is wider, thus the body is wider and the cargo area is longer so you will have ~6" gap when the jump seat is folded up.
Old Aug 12, 2009 | 09:24 PM
Dunno where you guys heard of cutting or welding or anything like that, just love all the "myths" / bulls**t that floats around lol, its a BOLT in job, simple as that. Land Rover even do a "kit" for you to do it.
If you have access to the donor vehicle, ALL the parts can be swapped over.
Old May 14, 2010 | 04:19 PM
thehulk's Avatar
So has anyone ever done the bolt in version?? If so, please post with pics, I think this is a very valuable installation.
