Thoughts on reusing the oil pan gasket? Hear me out...
Old Nov 29, 2025 | 10:10 AM
Brandon318's Avatar
Default Thoughts on reusing the oil pan gasket? Hear me out...
I just replaced the oil pan gasket a couple weeks ago to shore up a small leak. The crucifix seals looked OK so instead of replacing them I decided to roll the dice and see if just the oil pan gasket alone would do it. Still have a small leak between the oil pan and the bell housing, so clearly didn't do it.
If I drop the pan in the next few weeks to replace the crucifix seals, what do we all think about reusing the new oil pan gasket?
Side question - I happened to remove the Y-pipe when replacing the oil pan gasket to install some stainless studs while I was in there, but would prefer not to remove it again since it's all sealed up and *finally* leak free. How's the oil pan/crucifix removal with the Y-pipe in place? I replaced the front three oil pan studs with bolts, so looking forward to that being MUCH easier to deal with.
Old Nov 29, 2025 | 04:24 PM
Extinct's Avatar
Sure, go ahead and reuse it with no problem. I like to skim coat it with a thin coat of RTV silicone. As far as getting the oil pan off without dropping the Y pipe that should be no problem but you're probably going to have to check the truck up so the suspension is at full droop and remove the front crossmember.
cvhyatt
Jan 14, 2022 07:55 PM
Rover_Hokie
Sep 27, 2012 04:42 PM
ngarover
Apr 16, 2012 09:48 PM
shonuff93
Oct 6, 2009 06:22 AM
kean
Feb 24, 2009 03:41 AM
