Thoughts on running M1 5W40 Turbo Diesel oil.
Old Jan 23, 2012 | 12:08 PM
SolbergFanBoi's Avatar
Originally Posted by Snafu / Disco Fries
That is the only oil I will let touch my Audi, as well as my previous twin turbo Audi. Great stuff. Just thinking with the older Rover that is running hot and may be a bit dirty, the TD formula could be good
Yes, a great oil as you already know... The 0W-40 will clean better than the TD formula, it has a more robust detergent package and damn near as good anti wear additive package. As a 0W oil, higher quality base stocks too
Old Jan 23, 2012 | 12:21 PM
Snafu / Disco Fries's Avatar
Good to know. My current S4 takes 10 qts of it at a time. I track that car sometimes so run it hard. I've sent the results to Blackstone and is always great. Used it. On two highly modded cars as well as was perfect. My previous twin turbo 6 had k04 turbos and 450hp. Put 100k trouble free miles with that oil, and those turbos when driven hard can easy cook bad oil.
I might give it a shot next time. Would make it easier to just buy one grade for both cars anyway!
Old Jan 23, 2012 | 12:44 PM
If it can take the punishment of track days in your modded turboed Audi's than it's obviously more than good enough for our Rovers. Good for you doing Used Oil Analysis too, a lot can be told by doing this and it's cheap! Plus, you get to learn a lot about engine oils and their chemical formulations.
birdhead
Aug 8, 2010 10:36 AM
viper205
Jun 17, 2008 07:44 PM
globallandrovers
Jan 21, 2008 01:53 PM
dmcmurtrie
Dec 8, 2007 03:46 PM
benji
Apr 27, 2007 01:29 AM
