Thread problems......
Old Nov 14, 2015 | 03:24 PM
lrguy46's Avatar
Default Thread problems......
Hi
I've worked on cars since the early 60's but will be the first to admit that my knowledge of the intricacies of the Discovery's engine were zero when I have started on it but I have learnt a lot since, mostly from posts here.
That said, I noticed, when dismantling this engine, numerous bolts and nuts were missing including some quite crucial ones. I had noticed, when I first purchased the car, that the engine note was slightly odd though I couldn't put my finger on it...
Move forward many months with me reassembling the engine and I noticed that I had only removed 15 manifold bolts so when it came to refitting the manifold I discovered why... the right side front lower manifold hole has a damaged thread and the cowboy that worked on the engine before didn't bother to try and fix it. He just left the bolt off....
I knew I had a fairly comprehensive metric tap and die set at my electronic workshop and whereas a 10mm 1.6 pitch die fitted the new manifold bolt perfectly, I did not have a matching tap in the set... only a 1.5 pitch 10mm tap.
A trip to Home Depot only located another 1.5mm and Autozone had nothing.
I am hoping that running a tap into hole will restore the thread enough for the bolt to engage as the next step... that I would like to avoid... would be a helicoil insert. I might have to pull the head off again to do that....
What are expert thoughts on this and where can I get a 10mm x 1.6 here in the USA? Having done a Goggle search I can't even locate one and am beginning to doubt 1.6 except the die fits it perfect whereas the 1.5 die didn't.
AGH!!!!!! I just checked the Rover North site and it's a 3/8" UNC thread... the UK has been metric since 1976 who would have guessed the @#$% thing was UNC?
Postscript:- My local hardware store had a 3/8" taper tap and a gentle tap with a 4lb hammer persuaded it into the hole over the problem entry threads. Rather laborious turning the tap 45 degrees at a time but once driven all the way in and extracted, the manifold bolt started easily in the thread.
A P.I.A morning but at least I had more gumption than the "mechanic" that chose to leave it minus bolt!
Old Nov 16, 2015 | 04:17 PM
lrguy46's Avatar
And just to complete my misery with the reassembly task...
I had been ultra careful to lay out the parts removed on a long bench and discovered, to my horror, with the hindsight that new found knowledge brings, that the @#$% that last worked on the engine had not fitted any of the secondary air vacuum hoses. The car would still run as normal and I recall hearing the compressor run, but without the vacuum there would be no valves sending the air to the exhaust valves.
Another sorte at Rover North it seems....
LRDISCO
Nov 27, 2020 07:20 PM
Frank4
Mar 21, 2014 05:21 AM
devicespy
LR2
Mar 23, 2008 04:42 AM
Ranger_bah
Dec 25, 2006 07:16 PM
SJT
Aug 29, 2006 08:26 PM
