Three Amigo Fault
Three Amigo Fault
I have been getting very intermittent amigos. Its more common now, I have been pulling a myriad of codes over the years.
The below are the most common ones, given the right rear sensor output low is the most common, does it make sense to replace the rear hub first? I have done option B. I can go months wo an Amigos, and sometimes it is nearly constant. I can not seem to find a cause or correlation.
If anyone wants to borrow the ABS Amigo, please dm me.
-Current Faults---->
Active Faults:
None
Logged Faults:
020:No batt supply voltage
047:Rear Right sensor output low
114:Shuttle Valve Electric Failure
<-END Faults
..--Previous Faults--->
Active Faults:
None
Logged Faults:
Active Faults:
None
Logged Faults:
012:Pump fail monitor line
035:Rear Right out valve open circuit
040:Pump relay open circuit
<-END Faults
Active Faults:
None
Logged Faults:
<-END Faults
Active Faults:
None
Logged Faults:
Active Faults:
None
Logged Faults:
<-END Faults
