Three Amigo Fault
Old Aug 11, 2024 | 11:24 AM
redrover75's Avatar
Default Three Amigo Fault
I have been getting very intermittent amigos. Its more common now, I have been pulling a myriad of codes over the years.
The below are the most common ones, given the right rear sensor output low is the most common, does it make sense to replace the rear hub first? I have done option B. I can go months wo an Amigos, and sometimes it is nearly constant. I can not seem to find a cause or correlation.
If anyone wants to borrow the ABS Amigo, please dm me.
-Current Faults---->
Active Faults:
None
Logged Faults:
020:No batt supply voltage
047:Rear Right sensor output low
114:Shuttle Valve Electric Failure
<-END Faults
..--Previous Faults--->
Active Faults:
None
Logged Faults:
Active Faults:
None
Logged Faults:
012:Pump fail monitor line
035:Rear Right out valve open circuit
040:Pump relay open circuit
<-END Faults
Old Aug 11, 2024 | 07:04 PM
Extinct's Avatar
a bit of bother, but you could change sensor left to right and see if it follows. How many miles? The hubs don't usually start to give trouble till well north of 140.
Old Aug 11, 2024 | 08:52 PM
redrover75's Avatar
I am at ~146k miles. Seems to jive with your observation.
Might be worth a shot, can the sensor be pulled out from the back? Or does the wheel have to come off?
Old Aug 12, 2024 | 05:04 AM
Extinct's Avatar
Wheel does have to come off, don't remember which but either front or rear hub has to come out a bit too.
Old Aug 12, 2024 | 01:27 PM
redrover75's Avatar
Thanks, I think I have to go 80% of the way, might as well put in a new hub, save the inevitable time.
Old Aug 12, 2024 | 06:28 PM
Extinct's Avatar
The one issue with just dropping in new is if it does not change then you are suspecting the new part, lots of stories about new parts not being up to snuff.
redrover75
Apr 21, 2024 07:08 PM
redrover75
Feb 24, 2022 02:53 PM
KlamathMatt
May 8, 2013 09:13 AM
bosshogt
Sep 18, 2010 01:16 PM
booman
Nov 30, 2009 09:54 AM
