Three Amigos Codes
Three Amigos Codes
What are the exact codes to be cleared to correct the Three Amigos? Just had differential lockers installed and have the Amigos. Need to tell the corner mechanic which codes to clear. Thanks.
Also, having major overheating problems. Recently replaced the 4.6L motor with a used 4.0L and have had lots of problems. Replaced the thermostat but that is not helping. No fluid leaks, nothing. Vehicle just overheats. Ideas? Thanks.
David
David
I understand. As they appeared after installing the Ashcroft ATBs, I thought this might be a common problem with specific codes.
Frank4
12-07-2019 02:19 AM
