Three Amigos Codes
Old Nov 25, 2020 | 11:40 AM
dcaven's Avatar
Default Three Amigos Codes
What are the exact codes to be cleared to correct the Three Amigos? Just had differential lockers installed and have the Amigos. Need to tell the corner mechanic which codes to clear. Thanks.
Also, having major overheating problems. Recently replaced the 4.6L motor with a used 4.0L and have had lots of problems. Replaced the thermostat but that is not helping. No fluid leaks, nothing. Vehicle just overheats. Ideas? Thanks.
David
Old Nov 25, 2020 | 06:13 PM
mollusc's Avatar
There are something like 14 different scenarios that can cause the three amigos, and clearing codes won't fix the the underlying physical conditions that are causing the lights to show.
Old Nov 26, 2020 | 12:25 PM
dcaven's Avatar
I understand. As they appeared after installing the Ashcroft ATBs, I thought this might be a common problem with specific codes.
Old Nov 27, 2020 | 04:58 AM
JUKE179r's Avatar
All fault codes should be cleared.
As for overheating... air in system? old coolant? low on coolant? incorrect t-stat? clogged rad? bad water pump?
DiscoNickBK
Oct 1, 2018 07:27 AM
me 2
Apr 9, 2013 12:12 PM
GadgetRick
Feb 9, 2012 10:18 PM
jpluncford21
Aug 3, 2011 02:14 PM
