Three Amigos finally here. Amigo anyone?
The three amigos have made an appearance on my Rover. They were intermittent for a few days, but seem to be locked in now. I bought the old girl 4 years ago and at 150k miles now, I consider myself lucky to have not had to deal with the lights until now. I’m guessing there is nothing I can do troubleshooting wise until I get my hands on a scanner to read the ABS codes.
Is there anyone in the Philadelphia/ South Jersey area that owns an Amigo scanner I could borrow or rent? Shoot me a PM or email at jami.dstasio@me.com
Thanks in advance
Thanks in advance
I just had the amigo problem. Mine was the shuttle valves. Make sure you get the codes read so you know for sure. If it is the shuttle valves do option B in the sticky above. I didn't buy new switches because I felt that the switches were fine. I replaced the seals and did the wire cutting and bam I am good. However make sure you do it when the amigos are off so you don't have to have someone clear it with a amigo scanner! If it is the shuttle valves let me tell you that the little locking washer/clip inside the the slabs control unit SUCK to get off. They are so small and pop off easily. They are easy to get on though because you assemble everything before it goes into the slot.
you should probably get on to our club forum.. lots of local guys near you. if you ever come to one of our outings i always carry the club amigo with me. start simple. go to a spray car wash and spray your brakes down when you do a car wash. dirt and brake dust is an easy fix.. could be a million other things though, abs sensor, shuttle valves, hub etc etc
I've also sent a message to join NELRC & am in the process of checking out the Facebook page. I hope I didn't miss out on the summer outings yet.
you just missed a big one in the beginning of June but we are going to be back down in the Pines in August, Viriginia in Sept, PA in October, Jersey in Jan 13...
replied to your email.
if i were going to redo mine i would go Ferodo or EBC but right now i have cheapies on there because its only a trail truck. also get yourself one of these if you haven't already. it will fail and leave you stranded in park. Brake Light Switch & Wiring Assembly Kit (Genuine Part # XKB500120) - Land Rover switches from Atlantic British
