Three Amigos and Pump Relay Open Circuit
Old Sep 2, 2015 | 11:06 AM
DStern1821's Avatar
6th Gear
Default Three Amigos and Pump Relay Open Circuit
I am preparing to fix the three amigos in my 03 Disco II. I have the falconworks shuttle valve and seals, intending to do "option b". Purchased a Nanocom to assist with the brake bleeding. However, I am puzzled by the ABS fault the Nanocom indicates "16-01 pump relay open circuit" INTERMITTENT 016 times". Not the error code I was expecting.
Any thoughts or direction would be greatly appreciated.
Dave
Old Sep 2, 2015 | 12:00 PM
ATLDisco's Avatar
I am unfamiliar with the Nanocom, but I can offer this: of the 5 discos that I have owned, ALL of them benefitted from the grounding mod.
I'd venture a guess that "open circuit intermittent" means something isn't quite right with the electrical part.
And a good ground can in no way harm your current situation.
Also, if you pump is FUBAR, go pull one from a yard. I've bought perfectly good ones for $80-ish, then clean and re-seal. And re-ground.
Old Sep 2, 2015 | 01:22 PM
cybercop's Avatar
Peaked my interest. What is the "Grounding Mod"
Are you talking about a "Big Three" Mod. Positive from Alternator to Battery; Engine ground to Chassis ground or Battery negative; Battery negative to Chassis ground?
or
Ground Mod. The only grounding mods I am aware of are the ones you use for Unibody cars, which our Rovers are not. But I have seen these make a world of difference on old Jap Unibodies.
Does a Grounding Mod on the Disco comprise of some ground flow from the negative battery terminal to different points on the sub frame?
Really interested in this!
Charlie_V
Aug 27, 2015 04:37 PM
briancbev
Apr 24, 2014 09:13 PM
Rover Rog
Sep 17, 2013 01:22 PM
jw928
Dec 19, 2008 01:06 AM
erike1
Sep 1, 2006 02:08 PM
