Three Amigos and their codes
Started getting the three Amigos with greater frequency. I bought an ABS Amigo which read the following codes:114:Shuttle Valve Electric Failure (current fault) and these:022:ECU Gnd or Reference Gnd bad (previous faults 1) and finally these:022:ECU Gnd or Reference Gnd bad
064:Front Right sensor electric fail
065:Rear Left sensor electric fail
066:Front Left sensor electric fail
067:Rear Right sensor electric fail (previous fault 2)
All that being said, given the number of times the amigos have appeared, I would have thought there were more faults. Also, if I shut the vehicle off, 90% they do not reappear for a while?
Any thoughts from the duty experts?
on
How many miles on your truck, when did you last do a full 2 quart DOT4 brake flush?
Start by reading Josh's write up on the ground and shuttle valve replacements. Do both repairs and clear your codes, see which of the other codes comes back.
If you have any questions, send me your number and I'll call you.
"winston" has 66k on the clock. The brake flush is on my list as is the transmission. I cleared the codes with this amigo read and I was thinking that I would start with the flush before I got into Joshs' repair. What are your thoughts? I am reasonably handy and have backup if get in over my head
Just a note: The seals in the shuttle valve don't have to be leaking for the shuttle valve switch to fail. When I dove into my Amigos, my shuttle valve switch tested bad, but it was dry as a bone. I replaced the seals with the FalconWorks kit, and did the ground repair as per Josh's writeup, since I knew both were potential problems that would appear at some point in time, and since I was already right there.
Public service announcement:
To all folks, I have the ABS Amigo back and available to rent. Here is my policy. $200 to rent the ABS Amigo for 2 weeks via PayPal
$160 refund when I receive it back (Rental is $40) Renter pays return shipping. I pay shipping to renter.
$15 each additional week past the first two weeks.
I can send you a PayPal invoice if you prefer. Send me a private message if you need it.
marsyas
02-25-2021 08:11 AM
