Three amigos when shifting gears?
I did a search for the tres amigos but none of them seemed to be intermittent problems, only locked in issues.
Anyway, just this evening when I shifted from drive to reverse, I got my first 3 amigos. I started the car back up and the lights were cleared.
Later, as I was backing out of my driveway to turn the car around, it happened again. I turned the Rover off then back on and the problem cleared.
It only happened when shifted from Drive to Reverse on both occasions with my foot on the brake.
Weather:rainy and cold....might be important.
A month ago, I posted about a similar issue that happened twice...the M + S lamps flashed under the same conditions (shifting gears while stopped and the weather was cold and rainy).
The M + S problem hasn't cropped up since, but now I get the Amigos twice in one night.
The stealership is almost 90 minutes away and there's no local Indies equipped to pull the codes.
Do I have something simple that might be weather related or isanything I should be looking at to see if I have something more serious going on?
Edit: brakes and rotors changed last Spring at 49k if that's helpful.
tre soli
01-01-2014 12:40 AM
