Throttle body
Old Dec 8, 2008 | 02:36 PM
baddiscoII's Avatar
Default Throttle body
Just had my truck overheat. Guy who looked at it say the throttle body is bad. I found the leak and I was wondering if you had to replace the wholebody or just the part with gasket and two hose outlets? Can you do anything for leaking air suspension? Thanks for the help.
1999 discovery II 108000 miles.
Old Dec 8, 2008 | 03:57 PM
Switzer's Avatar
Default RE: Throttle body
http://www.roverparts.com/Parts/MGM000010KG.cfm
This will fix it.
Cheers,
Pete
Old Dec 8, 2008 | 04:36 PM
hazletbassist89's Avatar
For your air suspension you will either need new bags (quite expensive, will need to be replaced again) or just dump the air suspension and have them replaced with coils (rides the same, won't need replacing again)
Old Dec 8, 2008 | 05:02 PM
Switzer's Avatar
ORIGINAL: hazletbassist89
http://www.roverparts.com/Parts/9268D2ABP.cfm
Cheers,
Pete
Old Dec 8, 2008 | 06:17 PM
Send me your tele number, I'll be glad to help you with the suspension.
SenatorPerry
Jul 15, 2013 10:28 AM
bigugly82
Oct 15, 2007 04:18 PM
jdelp
Mar 7, 2007 08:45 PM
Desert Fox
Feb 27, 2007 12:35 PM
Doss
Mar 26, 2006 06:00 PM
