throttle body bypass
Old Jun 12, 2010 | 07:33 AM
buick215's Avatar
Default throttle body bypass
My throttle body is leaking and I would prefer to just bypass it since I don't use the vehicle in cold weather and it is the second time in two years (10,000 miles apart) that it leaks. I would like to know which is the best way to bypass it. I have read on this forum that there are two ways to bypass it. One is to join the two hoses with a short copper pipe and the other is to eliminate the short hose and connect the longer hose to the plastic pipe. I would like to know which one is better or if there is another more reliable or practical way. On a side note the coolant was replaced when the throttle body was replace so I don't know why it lasted so little. Thanks and sorry for the newbie questions.
Old Jun 12, 2010 | 07:37 AM
03discoman's Avatar
i took a bolt and inserted it into the hose coming from the expansion tank and used a hose clamp...... same thing for the intake manifold side...
i live in Michigan and my tb didn't freeze last year!!!
Old Jun 12, 2010 | 07:44 AM
buick215's Avatar
Is there an advantage by not having the coolant circulate thru the hoses? I was under the impression that the coolant had to continue to flow thru, but apparently I am wrong.
Old Jun 12, 2010 | 07:57 AM
Do as you mentioned, us a piece of pipe bent into the shape of a C and join the two hoses together, I did this nearly 7 years ago and have been leak free since.
Old Jun 12, 2010 | 08:07 AM
buick215's Avatar
Thanks Mike, soon after I purchased the truck, 2-3 years ago, I had the 60k service done and have been on top of all of the maintenance requirements so I was not expecting to have to deal with the throttle body so often but the more I read the more that I become aware that they are a common problem.
j.dstasio
May 10, 2021 11:33 AM
mln01
Feb 2, 2015 08:19 AM
wynhd
Nov 21, 2013 10:40 AM
Ghaniba
Mar 6, 2013 07:52 PM
humroot
Mar 21, 2008 01:55 PM
