Throttle body heater, p1171 and p1174
Old Mar 7, 2015 | 03:25 PM
lordmorpheus's Avatar
Originally Posted by ST_Farms
Another easy way spray a little starting fluid or brake clean along hoses when it revs up a little theres your leak.
X2 on this! This is my go to method for tracking down vacuum leaks that aren't evaporative emission component related. With engine running, spray along vacuum lines, elbows and fittings. When the engine RPM goes up, you have found your leak as the combustible starting fluid is being added to intake.
Old Mar 10, 2015 | 06:21 PM
DiscoDubs's Avatar
X3 on brake cleaner, use the straw so you can be accurate and isolate the leak, mine was the injector O-rings as well.
sickws6
Dec 14, 2013 07:24 PM
ycc456
Oct 28, 2013 12:43 AM
bwilliam
May 14, 2012 12:09 PM
Dino76
Aug 3, 2011 08:48 AM
steinj
Jun 29, 2007 05:58 PM
