Throttle body heater plate factory hose clamp size/source
Old Nov 16, 2020 | 02:02 PM
neuropathy's Avatar
Default Throttle body heater plate factory hose clamp size/source
Does anyone know what size clamps are needed for the two hoses on the throttle body heater plate? I’d like to replace the clips that someone put on here with the click-type clamps, but I want to be sure I’m getting the right sizes. Does anyone know a good place to get them? It seems AB sells worm drive clamps and I’m not sure about the quality of the ones from other sellers online.
Old Nov 16, 2020 | 02:06 PM
Dave03S's Avatar
Generic stainless worm style clamps have been working fine for me for years now.
Old Nov 16, 2020 | 02:12 PM
neuropathy's Avatar
I tend to like them too, but the clamps on the heater plate going to the expansion tank have some kind of squeeze tabs on them and I hate them. Are these on those hoses from the factory? I had a hell of a time with them and I think they cut into the hose. The end by the heater plate is now a bit cut up. It doesn’t seem to be leaking, but should I still replace this hose immediately? I’m wondering if I can do this with coolant on the system.
When I replace it, I’ll use the worm drive clamps. I tend to like the factory clamps since they’re somewhat idiot proof, clamping at the correct amount where I might over or under tighten another clamp.
I guess these are factory clamps for this line
It’s the end at the throttle body heater plate that got chewed up in the work I just did. I’m hoping the hose is still ok. Does the fatter part just cover up more of the skinny part of these hoses, or does it adapt at the ends? Wondering if I have to replace it right away or if it’s fine if it’s not leaking immediately after the work.
Old Nov 16, 2020 | 02:47 PM
Dave03S's Avatar
The clamps in your pic are not factory style. OEM clams are the ones with the small tab that locks in place over the slight hump as seen in this historic thread from the past...
https://landroverforums.com/forum/di...mp-clip-74297/
Old Nov 16, 2020 | 02:57 PM
neuropathy's Avatar
I see. So this line I’ve got is aftermarket. These genuine lines seem to have a different type of clamp, but it’s hard to see. I like the click clamps though. Any advice about genuine vs aftermarket rigid lines like these and other hoses? Can it be replaced with a full expansion tank?
Old Nov 17, 2020 | 04:40 AM
JUKE179r's Avatar
IMO... remove theTBH stock black plastic rigid coolant line and replace with a 5/16"/8mm ID flexible coolant hose.
I've replaced both of my plastic rigid coolant lines (top radiator to expansion tank and TBH bypass) with red 8mm ID HPS brand silicone heater hoses.
Old Nov 17, 2020 | 06:47 AM
Dweeb Discovery's Avatar
Dude. You're overthinking this. They're just hose clamps.
Yes, I suppose it's possible to overtighten or undertighten a worm clamp, but it's also easy to get it right. Just snug it up and check for leaks, and don't put on your Incredible Hulk. I like to use a nutdriver instead of a screwdriver for a more positive fit. And whatever clamps that come with the aftermarket line are probably okay too.
And for replacing the line with a full expansion tank, I'll presume you mean without emptying the coolant reservoir. Yeah, you can do that if you're quick about it but you'll lose at least a little coolant. Just be very careful to not stress the nipple on the reservoir; they're prone to breaking.
Why are you replacing the line in the first place? What's connected to the nipple on the reservoir now?
Old Nov 20, 2020 | 03:38 AM
neuropathy's Avatar
As it turns out, the other hose is leaking a bit (the inner hose on the heater plate). I’ll have to see what I can do about that.
About what's connected to the nipple, do you mean the hose that runs go the heater plate or the type of clamp? I think it’s one of those squeeze clamps on a rigid plastic line that has fatter, rubbery ends - I think there are two clamps on each end. The end at the throttle body heater plate got chewed up in removing it from the old plate since it was fused onto the thing.
I don’t think that ones even leaking on the end though... I’ll have to check the lines again. The day got dark fast and it took me enough time out there just to get to that point so I’ll have to look again.
Old Nov 20, 2020 | 03:40 AM
neuropathy's Avatar
Do you mind sharing a photo of this? That sounds like a good plan and from what I understand, I should install a catch can there...
j.dstasio
May 10, 2021 11:33 AM
Chrisinhouston
Mar 8, 2020 03:54 PM
binch
Oct 9, 2019 04:19 AM
SwimLSU
Dec 29, 2017 09:39 AM
matt3502
Oct 20, 2010 12:39 PM
