Throttle body replacement
Old Oct 20, 2010 | 10:59 AM
matt3502's Avatar
Default Throttle body replacement
Many kudos to Hilltoppersx for spotting my coolant leak while we worked on the 3 amigos. Going to replace the Throttle body heater plate this weekend. Is it advisable to replace the hoses as well?
Old Oct 20, 2010 | 11:02 AM
yloDiscoII's Avatar
Originally Posted by matt3502
Many kudos to Hilltoppersx for spotting my coolant leak while we worked on the 3 amigos. Going to replace the Throttle body this weekend. Is it advisable to replace the hoses as well?
I assume you are talking about the throttle body HEATER PLATE? then it probably wouldn't hurt to refresh the hoses, but not necessarily a must if the hoses are in good shape. DO however, replace the clamps with worms style clamps instead of the crappy "snap" clamps that come from the factory. Good luck with the fix!
Old Oct 20, 2010 | 12:25 PM
hilltoppersx's Avatar
Matt, i think your hoses are fine. I would replace the clamps with the worm clamps like Rob said. and double check the rest of your worm clamps to make sure they are tight. if you run into any problems give me a call im around saturday.
Old Oct 20, 2010 | 12:39 PM
matt3502's Avatar
yes, the heater plate, my bad. Thanks for the advice on the clamps guys.
SenatorPerry
Jul 15, 2013 10:28 AM
RANDY04D2
Jun 19, 2012 07:25 AM
2003landroverdiscovery
Jul 16, 2010 04:29 PM
Frank4
Nov 25, 2009 11:49 PM
Doss
Mar 26, 2006 06:00 PM
