Throttle body AND water pump
Old Dec 30, 2008 | 09:59 AM
JC316's Avatar
Default Throttle body AND water pump
I just spoke to a representative at the dealership today and they told me that they found the coolant leak. He said there was a problem with the throttle body and the water pump and that they both needed to be replaced. The problem is the qoute that he gave me was $1000. Is this relatively a good price? I'm guessing it's probably not because I'm dealing with the stealership here..... How difficult is it to replace the 2 pieces yourself? I'm a novice (at best) mechanic... How much would those pieces cost me? Am I better off just having them fix it? I was told that I wouldn't have any issues driving it but, that the coolant leak would eventually get worst!
Thanks for all your help in advance
JC
2003 Lando Discovery II 92,000 Miles
Old Dec 30, 2008 | 10:34 AM
Default RE: Throttle body AND water pump
The throttle body heater leak is VERY common and is a cheap fix.
As for the water pump, a LR pump is expensive, $400-$500, plus labor. Which at a dealership is expensive, over $100 per hour and the water pump bills out just over one hour, so they will bill you for 1.5 hours for a 1.2 hour job.
The throttle body is a.5 billable hourrepair, so thier pricing is on par, I would not pay that...but it is on par.
I would take it to another shop and have them replace the water pump and then fix the throttle body heater plate myself.
http://www.roverparts.com/Parts/STC4378OE.cfm
Here is the leaking throttle body gasket.
http://www.roverparts.com/Parts/ERR6623.cfm
You can replace just he gasket.
Or
http://www.roverparts.com/Parts/MGM000010KG.cfm
Find a indie shop that will install your parts and they just charge you labor.
Old Dec 30, 2008 | 10:47 AM
JC316's Avatar
Awesome! You're always a great help Phil! I know just the place that will do that kind of work for me!
Old Dec 30, 2008 | 10:53 AM
Always glad to help, I also have one of those kind of shops. For a flat $60 in cash they will fix anything.
vishrb
Mar 10, 2015 06:21 PM
SenatorPerry
Jul 15, 2013 10:28 AM
avking
Jan 11, 2009 09:05 PM
Desert Fox
Feb 27, 2007 12:35 PM
Doss
Mar 26, 2006 06:00 PM
