Ticking noise
Old Sep 1, 2006 | 06:37 PM
vmann7's Avatar
Default Ticking noise
Hi, I'm new to land rovers so please bear with me. My wife's 04 discovery is making a ticking noise. Its actually the lousest when you're standing by the vehicle by the drivers door while its idling. First time the dealer said they didn't hear anything. After taking the service advisor outside he heard it and said it sounds like an exhaust leak, which was my thought. Now today I get a call and they said the noise is actually the secondary air pump and its normal. In my experience with other vehicles a ticking noise is not normal. Any ideas? Thanks.
Old Sep 2, 2006 | 10:51 AM
Default RE: Ticking noise
Call customer service and let them know what is going on and that you want the noise removed.
Mike
Old Nov 9, 2018 | 01:44 AM
Anthony Frantzis's Avatar
Default Ticking
Sad yet true. I'm also a victim to what they informed you which was a lie. It's not normal. I've done research on this issue for some time and it result it was a defect on land rover for these engines ,(03,04) they were the upgrade from 4.0 to 4.6 and the oil sludge and causes the lifters to make that noise. I have the same issue and been told the quality of oil (Royal Purple) can help at early stages to eliminate that noise. Tree dealer told me it was normal when i first was looking to buy and i believed it half somewhat then again knew it wasn't.
Old Nov 9, 2018 | 05:06 AM
redwhitekat's Avatar
Hopefully you got a new engine under warranty
Old Nov 9, 2018 | 10:13 AM
Richard Gallant's Avatar
Good quality oil helps, running Rotella T4 for a few oil changes helps too it really cleans out the sludge. The SAI will be loud when you 1st start for maybe a minute or 2 then it will quiet right down.
15/40 or 15/45 seems to be a nice weight for these.
Old Nov 9, 2018 | 10:28 AM
Dave03S's Avatar
A lot has been learned since this thread started 12 years ago.
SAI can make a ticking noise, when the SAI valves stick and force exhaust back into the pump, you will hear a tick and a burble from the SAI.
Vacuum leaks cause a tick.
Exhaust leaks cause a tick
Mechanical issues cause a tick.
Etc.
garywwood
LR4
Aug 12, 2020 08:32 AM
KernowDiscovery
May 30, 2014 10:44 PM
Rustic
Jan 19, 2010 10:59 PM
gsxrgessler
Nov 3, 2007 04:03 PM
pickps
May 14, 2007 12:42 PM
