Ticking Noise After Warmed Up
Old Aug 13, 2013 | 08:04 AM
drowssap's Avatar
I see you got safety Allen's, but never wired them together
Old Aug 13, 2013 | 09:12 AM
Jason428sc's Avatar
They are all saftey wired together. The picture was taken before I wired them. Thats the only pictures I have. I should have taken more.
Old Aug 13, 2013 | 09:41 AM
me 2's Avatar
Default stuff
How did you know which cyls to pin?
Old Aug 13, 2013 | 09:56 AM
poncePR's Avatar
Most people pin all 8 cyl.
Old Aug 13, 2013 | 09:58 AM
me 2's Avatar
Default stuff
Also, do you have any good links for info? Thanks
Old Aug 13, 2013 | 09:59 AM
Jason428sc's Avatar
I didn't know which sleeve was slipping so I pinned all of them. All of the write-ups I read said to pin all of them or at least as many as you can. I was able to get to all of them by taking off the oil pan, "Y" pipe, engine mounts and exhaust manifolds. Of course you need to use an engine hoist to support the engine w/ the mount out.
Old Apr 23, 2020 | 08:52 AM
newworld's Avatar
00 discovery 2 4l. 225k
had a blown head gasket as i had low compression in cyl5. i pulled engine, heads etc, and found no steam cleaning in cyl5 and no evidence of head gasket failure. i did have coolant consumption and a ticking noise for a long time.
replaced the rings in cyl5, checked the heads and block and all were good...no warpage.
i pinned all 8 cyl, and replaced all bearings, main and rod found some wearing in all, and replaced all gaskets, timing chain and oil pump...oil pump was not broken as others have shown.
after reassembly, still get ticking only after engine is warmed up...i think the ticking maybe due to multiple reasons and not every disco will be the slipped liner. i would have sworn that mine was a slipped liner but no evidence at all of that on inspection. all liners were in place and the head gasket had not markings at all.
the rockers and pushrods were tight, there was no loose pushrods on inspection.
my thinking now is that maybe a lifter, or as other poster said a cam bearing is worn and no harm to engine to drive around...
i also checked cam for wear and all lobes were good.
so the conclusion to my story...it may be the liner or may not be...and i actually was the one who pulled the engine and took it apart.
Old Apr 23, 2020 | 09:03 AM
Sixpack577's Avatar
What did your rod and main bearings look like?
Were they worn out?
Chances are the cam bearings have the same amount of wear, and could be your noise.
They will also be a pain to do with the engine in, and the rear bearing will unfortunately be almost, if not impossible to replace with the engine in.
I chased a loud tick/tapping after warm up, and replaced parts individually and in groups, and worn bearings were my noise(rod, main, and cam).
Humdinger
Oct 18, 2016 05:05 PM
tom@intersoft.net.au
Freelander
Dec 30, 2013 09:57 AM
dms6601
Nov 18, 2013 08:15 PM
john65b
Oct 10, 2013 05:00 PM
DiscoV8'97
Sep 13, 2013 03:26 AM
