Ticking and Rattling, expertise requested
Old Sep 20, 2024 | 02:57 PM
nashvegas's Avatar
Doesn't sound too bad (or really that bad at all) to me. I've had alot of Disco2's. About half of them (esp facelift) have had that noise, without issue, for my entire ownership.
Agree 1100000% that putting the Rotella oil in is the way to go. That quiets them down !
BTW I only use genuine LR oil filters or Mahle and would recommend doing the same yourself, but ... you're prob fine with that other one. It's really just an oil filter.
Old Sep 20, 2024 | 02:58 PM
nashvegas's Avatar
PS get an ultra gauge and watch your coolant temps like a hawk. (read on here about it). I don't run any D2 without it in place, ever. Super key to preventing overheat which cooks head gaskets and motors.
Old Sep 20, 2024 | 03:21 PM
Casualfriday's Avatar
Thanks, that makes me feel better. My buddy gave me some Motul Hydraulic Lifter Care to throw in while my oil change. Any chance you've used it?
First item I bought was the ultragauge! Once I fully detail the interior, I'll be mounting that as right now I just have it sitting next to the transfer case shifter.
Old Sep 20, 2024 | 05:56 PM
gecko951's Avatar
Originally Posted by Casualfriday
Thank you! Thrilled to finally have one after stalking other people's for so long. Here's a picture from the ride home (I think she's Giverny Green but I'm colorblind so it mostly looks gray to me);
Wow, that is really nice and clean! Mine is Bonatti Grey and the metallic paint seems to make my significant other think its actually green.
Old Sep 20, 2024 | 06:09 PM
Harvlr's Avatar
And yes, watch the temp on the Ultragauge, but you can set an alarm on it to beep at a temperature that you set.
Old Sep 21, 2024 | 07:48 PM
Thank you! The wifey tells me it’s a jade or sea green - not that means anything to me as I’m color dumb lol
Is there a temp you would recommend setting the alarm at?
Old Sep 21, 2024 | 09:34 PM
whowa004's Avatar
do a full refresh on the cooling system (hoses, new rad, flowkooler pump, belt and pulleys), extinct inline mod, new fan clutcg and drive it after confirming temps. I don't run an ultra gauge so I don't become a slave to it. These motors are quite consistent once gone through ime and at NOVA elevations and temp range you'll be fine. I will check temps occasionally with a bluetooth dongle and app on my phone but it's not as dire imo as folks make it out to be if you start fresh and then maintain..
Old Sep 22, 2024 | 04:44 PM
Harvlr's Avatar
I set mine for 217*F. Others probably use a slightly different number
Old Sep 22, 2024 | 06:01 PM
Extinct's Avatar
All the trucks I sell come with an ultragauge, alarm set to 210. I do recommend it. Things can happen and you can experience an overheat even with a well maintained system and when you do it is at risk of blown hg or worse.
Old Sep 22, 2024 | 08:55 PM
Frank4's Avatar
Take a look at this UltraGauge mount. I bought one and it’s awesome. No better way to mount one.
https://goldenrovers.com/products/di...tragauge-mount
