Timing belt question
Old 04-05-2010, 02:58 PM
Carl082974's Avatar
Default Timing belt question
Does anybody know the recommended mileage interval / schedule for replacing the timing belt on a Disco II?
Are there tell tale signs that a timing belt is going bad?
(by the way, this is a 2001, Disco II, with 153,000 miles on it)
C
Old 04-05-2010, 03:31 PM
lipadj46's Avatar
your truck does not have a timing belt
Old 04-05-2010, 03:48 PM
NiteTrain's Avatar
it's got a chain not a belt. Some manufactures recommend replacing at 100K, but they will go 1M miles IMO.
Old 04-05-2010, 04:21 PM
okdiscoguy's Avatar
I replaced my chain and gear set @ 180K because I had the front cover off anyway. Probably could have left it alone.
Old 04-05-2010, 05:13 PM
If you have a diesel then yes, you have a timing belt and it is every 60,000 miles that it needs to be changed.
Old 04-05-2010, 05:48 PM
Does the DI have a chain and gear as well?
Old 04-05-2010, 06:08 PM
NiteTrain's Avatar
are you serious? they put belts on a the TD5? Well that makes perfect sense..don't want to hear that noise chain over your diesel engine
Old 04-05-2010, 06:27 PM
LOL!!!
I know the 200 & 300tdi's use timing belts but am not 100% sure about the TD5.
Almost all overhead cam engines use timing belts because they are quieter and cheaper than timing chains.
I think Nissan and Mazda (some models) use timing chains, my ex wifes MPV V-6 had a chain but my friends Protoge' had a belt.
Old 04-05-2010, 06:36 PM
okdiscoguy's Avatar
I figured he had a chain because it was listed in Miles.
Danny, you have a chain.
Old 04-05-2010, 09:03 PM
NiteTrain's Avatar
200 & 300tdi have a belt?? well that just kills my dreams. I guess that gives me another reason to use the benz OM617 engine for a diesel conversion one day.
Quick Reply: Timing belt question
