Timing Belt replacement
Old May 19, 2024 | 10:20 AM
Mando's Avatar
Default Timing Belt replacement
My 2001 Disco 2 has 198,000 miles, should I be thinking of replacing timing belt?
Old May 19, 2024 | 11:54 AM
Richard Gallant's Avatar
@Mando It is chain on these, it is a fair bit of work to get it replaced. Generally, unless you have used crappy oil or had really long oil change intervals they last pretty much forever
Old May 19, 2024 | 02:29 PM
Mando's Avatar
thanks for the prompt and useful reply Richard.
Old May 20, 2024 | 07:09 PM
Harvlr's Avatar
They last forever in the sense that they don’t break. They do stretch though, and lose power from the stretch as the valve timing gets worse. But, as Richard says, it’s generally not worth disassembling just to replace it. You should pretty much always replace it when you have the front cover off.
Old May 20, 2024 | 08:28 PM
Brandon318's Avatar
Also I'll add it's worth it to buy actual Land Rover replacement gears. The Allmakes replacement gears I got a couple years ago were absolute garbage quality compared to the originals. Something this critical deserves to be a genuine part IMO.
Old May 20, 2024 | 09:07 PM
Harvlr's Avatar
Or keep your original LR gears.
Carl082974
Apr 6, 2010 04:46 PM
91rover
Dec 7, 2007 06:53 PM
SpeedAgent
Sep 6, 2007 06:12 AM
jerrytrancik
Freelander
Dec 12, 2005 06:55 PM
tonygallagher
Oct 4, 2005 12:14 AM
