Timing chain oil? Cam bolt loctite? Front cover gasket application?
Old Aug 8, 2022 | 02:40 PM
neuropathy's Avatar
Default Timing chain oil? Cam bolt loctite? Front cover gasket application?
Hi everyone,
I have a few questions:
Do the new timing chain and gears go on without any oil, grease, lube, etc?
Should I use loctite on the cam bolt?
How exactly should the front cover gasket get applied? Just tacking and torque or a thin layer or high oil resistance silicone on both sides of the gaskets, finger tight, wait 24 hours, torque?
Thank you
Old Aug 8, 2022 | 03:19 PM
Brandon318's Avatar
Originally Posted by neuropathy
Hi everyone,
Thank you
I gave the timing sprockets and chain a nice waterfall of motor oil before reassembling.
The service manual doesn't specify any Loctite, nor does the engine rebuild manual.
I follow the service manual on this one, which doesn't specify coating the gasket with anything.
Old Aug 8, 2022 | 03:24 PM
neuropathy's Avatar
Thank you, do you install the bolts in the front cover without anything either? I already put the water pump on it and I used black silicone for that. Someone said to do that and someone else said it could get into the cooling system and cause problems, but I’m not sure if that’s correct - it’s supposedly able to take temperatures much higher than the water. I used it on the water pump gasket too. I’ve learned that everyone does things differently with their motors!
Old Aug 8, 2022 | 03:39 PM
Brandon318's Avatar
The way errant RTV affects the cooling system is by getting clogged in a tiny water passage, of which there are many. I didn't use sealant on the gasket or bolts and haven't had a leak.
99% of the time I follow the service manual. If it doesn't call for sealant, I don't use it. If it does, I do.
RoverSeriesInf
May 30, 2024 07:20 PM
me 2
Aug 12, 2021 07:02 AM
sumeet
Jun 9, 2015 01:11 PM
shezm
Mar 29, 2013 06:30 AM
shanechevelle
Nov 4, 2011 06:29 AM
