Timing Cover Removal
Old Oct 20, 2012 | 05:42 PM
Garhfer's Avatar
3rd Gear
Default Timing Cover Removal
Hey I removed the timing gear cover and there a metal tube looks like a bolt spacer laying in the oil pan after i removed the timing cover does anybody know where this spacer is supposed to go I don't see anything about it in the RAVE workshop manual thanks
Old Oct 20, 2012 | 05:43 PM
Garhfer's Avatar
3rd Gear
Also it's a 2000 Land Rover Discovery II
Old Oct 20, 2012 | 06:28 PM
Bkreutz's Avatar
Pictures would help, the only thing resembling what you describe is the spacer that takes up the space where the ACE pump is located on vehicles without ACE. It holds the serpentine belt cover in place. But this is only supposition on my part without seeing what you're talking about.
Old Oct 20, 2012 | 08:21 PM
Garhfer's Avatar
3rd Gear
I don't know if I have an ACE pump... but here's a couple of pictures
Size:  30.5 KBName:  Part-Landrover2.jpg
Old Oct 20, 2012 | 09:29 PM
LRScott's Avatar
As stated above, it does look like the spacer that is used on the serpentine belt cover that goes over the a/c compressor. I wonder how it got in your oil pan....
Old Oct 20, 2012 | 10:45 PM
Bkreutz's Avatar
If you have the ACE system, you will have 2 caps on your power steering reservoir, if only 1 then you don't and you will also have the spacer for the guard.
A5scott
Jul 11, 2015 07:25 PM
Martin Rodriguez
Feb 25, 2014 08:55 PM
tmtegt
Mar 20, 2013 07:31 AM
mcneal
Nov 25, 2008 08:10 AM
bazil
Defender
Apr 23, 2008 08:02 PM
