Tip for removing coolant pipe that goes into intake manifold?
Old Jan 15, 2022 | 07:51 PM
Brandon318's Avatar
Default Tip for removing coolant pipe that goes into intake manifold?
SUPER stuck in there. Safe to torch and heat the manifold around the pipe?
Old Jan 15, 2022 | 11:20 PM
Harvlr's Avatar
I would probably do it but very cautiously. The aluminum will expand more than the steel so you may not need a lot of heat.
Old Jan 15, 2022 | 11:35 PM
Brandon318's Avatar
How about using a heat gun instead of a torch? 🤷🏼‍♂️
Old Jan 18, 2022 | 02:38 PM
Harvlr's Avatar
Sorry for the slow response, I’ve been gone for a few days. I would for sure try a heat gun.
Old Jan 18, 2022 | 06:39 PM
mln01's Avatar
Why remove it? I think I left it attached to the manifold when I replaced the headgaskets on my truck 11½ years ago.
Old Jan 18, 2022 | 08:02 PM
zski128's Avatar
There is an o-ring in there that can rot out and cause a leak. Mine was also very stuck but I carefully wiggled it loose with a rubber mallet.
Old Jan 18, 2022 | 08:49 PM
Brandon318's Avatar
Heat gun for the win!
Old Jan 19, 2022 | 11:42 AM
Harvlr's Avatar
Great to hear
greenrovey
Apr 7, 2021 03:16 PM
keninnc
Nov 17, 2019 10:32 PM
04duxlr
Sep 29, 2014 09:18 PM
aftermath431
Jan 23, 2014 10:06 PM
marizcal
Oct 5, 2012 10:41 PM
