Tire fitting on discovery 2
Old Feb 13, 2013 | 10:40 PM
MONEYMIKE's Avatar
Default Tire fitting on discovery 2
Well i just bought a 04 discovery and want to put a 2 inch OME lift. So I want know if I can fit 275/75/R16 with the lift, which is like 32.2 inch tire ... Not sure correct me if i'm wrong. And i need to fit these tires without rubbing/rubbing when lock to locking with the steering wheel and no trimming.
Old Feb 13, 2013 | 10:42 PM
ZGPhoto's Avatar
It'll be close but you should be fine. I was not even close with 265/75s with a 2" OME lift.
Old Feb 17, 2013 | 12:30 AM
toofaroffroad's Avatar
first thing I did with my truck was a 2" lift and 285/75/16 (33/11/16) the front tires rubbed a tiny bit on full turn but it was fine articulating. I did end up lifting it another 2". But it was all good with the 2" and 33's.
Old Feb 17, 2013 | 12:55 AM
MONEYMIKE's Avatar
Where did it rub ?
Old Feb 18, 2013 | 01:35 PM
AU_LRDiscoII's Avatar
moneymike, i am looking to do the same thing to my 03 disco2. someone told me that you can buy certain heavy duty lifts that will raise you up about a inch more than what the lift says. if so i think you can fit the 275/75/16s under it without scrubbing. i think this only works if you dont use the heavy front and back bumper. i havent ordered my stuff yet because i dont know for sure what works yet. i dont want to trim anything but want to fit 33's.
Old Feb 18, 2013 | 01:37 PM
ZGPhoto's Avatar
RTE's lift will get you 3", Terrafirma's 2" HD lift will get you nearly 3" with no extra weight on your vehicle.
Old Feb 18, 2013 | 01:40 PM
would you go with a 275 or a 265 if you plan on going RTE and later going with a ARB bumper?
jafir's Avatar
My 255/85R16's fit fine with a terrafirma HD lift. I haven't trimmed anything yet.
Old Feb 18, 2013 | 02:07 PM
ZGPhoto's Avatar
Photos needed
Old Feb 18, 2013 | 02:18 PM
jafir's Avatar
Originally Posted by ZGPhoto
Photos needed
It's the same photos I've always posted.
EDIT: they are even in a thread you started: https://landroverforums.com/forum/di...rements-56226/
