Tire fitting on discovery 2
Old Feb 18, 2013 | 02:24 PM
ZGPhoto's Avatar
Haha right! I didn't realize you were running 255 85s in it. I've got a set of 255 85 16 KM2s in my garage just waiting for spring. Are you running different diffs/gearing/axles?
Old Feb 18, 2013 | 02:26 PM
wreckdiver1321's Avatar
DiscoRover007 did a similar lift, although his was a 2" Terrafirma, and he runs 275/65R18s with no rubs whatsoever. At a 275/75R16 you'll probably be just fine. That's the same width and only 1/4" taller as DiscoRover's tires. I doubt that extra 1/8" would cause you to rub.
Old Feb 18, 2013 | 02:57 PM
AU_LRDiscoII's Avatar
i have 255/65r16's on my stock suspension. i want to go with 285/75/16's. can i get that done with 3" RTE springs and new shocks. Am i going to have to trim alot off to fit these? i have to replace my shock anyway so i figured its time to start lifting. also 285/75/16's are a 33" tire?
Old Feb 18, 2013 | 03:01 PM
jafir's Avatar
I wish. It's kinda sluggish off the line, but I've driven a Jeep with a 2.8L V6... so it's not the slowest thing I've ever owned.
Old Feb 18, 2013 | 03:02 PM
ZGPhoto's Avatar
285/75 is a 32.83" tire, 11.2" wide. You'll be fine with the RTE 3" and no cutting.
Old Feb 18, 2013 | 03:39 PM
AWESOME, thats what im going to put on it then. last question im going to be doing light off roading mainly mud. should i go with a longer travel shock or just go regular. i was thinking +3 just so i would have them on there incase i get more into rocks and heavy off roading
Old Feb 18, 2013 | 03:46 PM
ZGPhoto's Avatar
Justin sells the Terrafirma +3" shock(TF133/TF134), I'd recommend it. I have them on the rear of my DII as the fronts are coil over shocks so with the spacers I didn't need them.
Old Feb 18, 2013 | 04:03 PM
thanks for the info guys yall have been a lot of help
Old Feb 18, 2013 | 04:04 PM
MONEYMIKE's Avatar
So can i fit 275/75/R16 on ome 2 in lift and i plan i putting a roof rack that would be holding a roof top tent and arb bumper , rock silders and maybe rear bumper with tire carrier lol would that rub ?!
Old Feb 18, 2013 | 04:12 PM
ZGPhoto's Avatar
Most likely, a 2" OME lift is IIRC a 1.5" lift, and that much extra weight would probably set you down quite a bit.
