Tire fitting on discovery 2
Old Feb 18, 2013 | 04:13 PM
  #21
jafir's Avatar
With +3 shocks, I'd certainly also do longer brake lines. (which I did.)
Old Feb 18, 2013 | 04:17 PM
  #22
MONEYMIKE's Avatar
Originally Posted by ZGPhoto
Most likely, a 2" OME lift is IIRC a 1.5" lift, and that much extra weight would probably set you down quite a bit.
So what if i get a 2 in terrafirma lift
Old Feb 18, 2013 | 04:22 PM
  #23
ZGPhoto's Avatar
If you get the HD version you'll be fine!
  #24
ZGPhoto's Avatar
+2!
No pun intended... but yeah I also got the SS +2" brake lines when I went to the 3" shocks.
Old Feb 18, 2013 | 04:23 PM
  #25
MONEYMIKE's Avatar
HD ome or HD terra?
Old Feb 18, 2013 | 04:25 PM
  #26
ZGPhoto's Avatar
HD Terrafirma, I believe there's a way to get 3" lift with D1 OME springs, but then you have to go elsewhere for the 3" shocks.
Old Feb 18, 2013 | 04:26 PM
  #27
MONEYMIKE's Avatar
I have a D2
Old Feb 18, 2013 | 04:29 PM
  #28
ZGPhoto's Avatar
I know, and I don't know the specifics(talk to DiscoMike), but people used D1 springs on their DII to get the 3" lift.
Old Feb 18, 2013 | 04:34 PM
  #29
MONEYMIKE's Avatar
One more question, do think bf goodrich makes 275/75/R16 KM2's mud terrain... All found was 265/75/r16 and 285/75/r16
Old Feb 18, 2013 | 04:40 PM
  #30
ZGPhoto's Avatar
I don't believe they do, I had 265/75 and moved up to 255/85. But 265 to 275 is a 10mm difference, hardly something you'll notice. I would go with the 265 because I like a skinnier tire...and girl...
