tire and lift qustions again
Old Nov 9, 2007 | 08:51 PM
blackdisco2001's Avatar
Default tire and lift qustions again
I have the ome lift, i think it might be the 2 or 1.75 inch i have seen bigger ome lift or are the same as i have but with spacers!!
Tires-- im running the 265-75-16(31 inch)but want to go to 255-85-16(33inch) what do you guys think will I have to change my gears what else will ihave to look for because my buddy has a d1 with 33-10.50-16 tsl super swompers and seem to run great
thanks
Old Nov 10, 2007 | 07:59 AM
Default RE: tire and lift qustions again
First of all, do you have a CDL t/case?
You will kill your gas mileage, you have already lost about 1.5 MPG going to the 265's, if you go larger, you will loose more and really have a drop in low end power. If you don't have a CDL, although you may want to go to gears and possibly lockers, it will help a little but you weak factory diff carrier won't hold up.
If you are planning on making some serious mods, you will have to make the big financial plunge.
abran
Jun 30, 2014 12:43 PM
brahall
Feb 1, 2012 07:33 PM
jpluncford21
May 17, 2011 12:31 PM
mcob02
Aug 22, 2007 07:28 PM
Disco_Rob
Feb 28, 2005 02:13 PM
