Tire rotation question on 1999 DII
I want to rotate my tires on a 1999 DII. Do the lug nut covers come off separately or with the actual lug nut? Can you use an imoact wrench to take these off? Thanks!
Phil
Phil
No the caps are designed to stay on. If you have been using an impact wrench you may have ruined them, and they are expensive.
Use a breaker bar with the correct size socket, I use a 1 1/16th. 6 point socket and torques mine to 102 foot pounds.
As for rotating, go front to rear and run all your tires at the same air pressure, I run 40 pounds of air.
Those specs. from the factory, are to give you a comfortable ride, not insure better mileage, tread life. If you measure the height of both tires, with a load on them, I believe you will find a difference which when the CDL and or lockers are engaged will cause an uneven strain on the drive train.
Running 40 pounds, I find I get a more even tire wear, only rotate them every 20,000 miles. I have also found that running higher air pressure, in my case 40 pounds, gives me nearly 1 more MPG.
So yes, I advise everyone to consider running higher, even air pressure in their tires.
I think its 46 psi rear if you have air suspension regardless of weight.
All of the stickers say 46. But if you look in the owners manual you'll see it says 38.
