Tire rotation question on 1999 DII
Old May 16, 2012 | 03:11 PM
pgk's Avatar
pgk
Default Tire rotation question on 1999 DII
I want to rotate my tires on a 1999 DII. Do the lug nut covers come off separately or with the actual lug nut? Can you use an imoact wrench to take these off? Thanks!
Phil
Old May 16, 2012 | 03:46 PM
No the caps are designed to stay on. If you have been using an impact wrench you may have ruined them, and they are expensive.
Use a breaker bar with the correct size socket, I use a 1 1/16th. 6 point socket and torques mine to 102 foot pounds.
As for rotating, go front to rear and run all your tires at the same air pressure, I run 40 pounds of air.
Old May 16, 2012 | 10:45 PM
pgk's Avatar
pgk
Do you see improved performance running 40 pounds of air? I have been running the recommended 28 front 46 rear.
Old May 17, 2012 | 09:06 AM
Those specs. from the factory, are to give you a comfortable ride, not insure better mileage, tread life. If you measure the height of both tires, with a load on them, I believe you will find a difference which when the CDL and or lockers are engaged will cause an uneven strain on the drive train.
Running 40 pounds, I find I get a more even tire wear, only rotate them every 20,000 miles. I have also found that running higher air pressure, in my case 40 pounds, gives me nearly 1 more MPG.
So yes, I advise everyone to consider running higher, even air pressure in their tires.
Old May 18, 2012 | 08:27 PM
buick215's Avatar
I also run them at 40 psi. Forget about the 28 front 46 rear thing. I used to go by that but realized that I had more even tread wear with the 40 psi all around.
Old May 18, 2012 | 09:00 PM
jafir's Avatar
You'll also note that the owners manual does not say 46 psi for the rears, unless at max weight. It says 38 psi, which is a lot closer to the 40 psi that a lot of people recommend.
Old May 18, 2012 | 09:01 PM
I rotate my tires everytime I drive.
Old May 18, 2012 | 10:23 PM
buick215's Avatar
I think its 46 psi rear if you have air suspension regardless of weight.
Old May 19, 2012 | 06:52 AM
jafir's Avatar
All of the stickers say 46. But if you look in the owners manual you'll see it says 38.
Old May 19, 2012 | 08:44 AM
SLS does not require more air pressure unless you throw more the 1000 pounds in the cargo are, then air up based on your tire/side wall rating.
jrb
Dec 23, 2012 09:02 AM
Willie00d2
Nov 14, 2010 07:11 PM
mishon
Feb 28, 2010 09:21 PM
mwsharb
Mar 12, 2009 07:52 PM
stupid
Jan 20, 2009 10:54 PM
