Tire Size
Old Jun 14, 2005 | 02:13 PM
jhstew1's Avatar
7th Gear
Default Tire Size
I currently Have 99 Disc. SD with 235/70-16's on it, anyone know what the largest tires i can put on w/o any lift kits or vehicle adjustments ?
Thanks..
Old Jun 14, 2005 | 02:38 PM
mikemeyer0's Avatar
Default RE: Tire Size
245/70-16 is as big as you want to go without lift, you may need to trim a bit if you take it off road. It is a D1 right?
Old Jun 14, 2005 | 03:26 PM
jhstew1's Avatar
7th Gear
ok thanks....it is a D1, 1999 last one they made before the DII......will probably just stick with the size I have
Old Jun 14, 2005 | 03:41 PM
mikemeyer0's Avatar
ORIGINAL: jhstew1
yea the reason i asked was cause i think there are some late 99 that are D2's. anyway, the stock size is good, you will loose bottom end power going to a bigger size anyway.
jigray3
Oct 14, 2010 06:54 PM
jigray3
Oct 9, 2010 09:27 AM
trini defender
Tires
Nov 30, 2006 03:31 PM
samsly
Tires
Feb 27, 2006 07:01 AM
chefman
Jan 18, 2006 10:15 AM
