Tires/ and slight antifreeze smell
Old Feb 4, 2007 | 12:49 AM
AustinAdam's Avatar
4th Gear
Default Tires/ and slight antifreeze smell
I am a new owner of a 2000 disco. Love the truck and hoping I dont have a ton of problems. I found some 19" OEM wheels with the same lug nut size, is it ok to put them on my 2000 disco?? I also notice the auxilary fan coming on (does it always run??) and a slight smell anti-freeze from time to time. I just had a land rover inspection done by an independent, and replaced a valve cover gasket, but that was all they found wrong. Wat should i consider before thinking its the head gasket??
Old Feb 4, 2007 | 10:57 AM
Default RE: Tires/ and slight antifreeze smell
19" ties are not worth a damm of the road, so if you want to go 4wheeling consider 16" factory wells.
Yes the fans will come on when the engine is running and getting a little warm or when the A/C is on.
As for the coolant smell, go have the trucks coolant system pressure tested ASAP to find the leak, this is important cause Rovers can eat head gaskets and if you over heat your engie, you can loose it.
Mike
Old Feb 4, 2007 | 01:20 PM
AustinAdam's Avatar
4th Gear
would the 19"wheel even fit the wheel well?? is is that terrible of a ride?? I paid almost nothin for the rims and was hoping to give my truck a freshdlook. my old rims are road rashed!
can you go almost anywhere to get it pressure tested?? or should i go toa land rover dealer/independent??
caymandrew
Mar 18, 2013 12:11 PM
Rearden Steel
Oct 31, 2011 09:22 PM
humroot
Jul 3, 2010 10:29 PM
zerochills
Jul 18, 2007 07:32 AM
resqguy77
Apr 30, 2006 02:53 PM
