Today I started the disco fiberglass sub box!!!
Old Feb 1, 2009 | 10:08 AM
Rover Chris's Avatar
Default RE: Today I started the disco fiberglass sub box!!!
yes if I remember correctly W0's were the only model they made the 6" in. They have now replaced the W0 line with the W1 line and only offer a 6" sub in the W3 line which if 2 of those would fit would be great since I am considering going with a 12W3 for my sub box! otherwise I will try to find 2 older 6W0's. But there again between the sub box materials and a new sub my expense allowance for this project will be all used up, so replacing the stock subs is a possibility down the road.
Old Feb 1, 2009 | 10:27 AM
Disco Dave's Avatar
my next project may be that sub box. so i got the nav and sat radio all installed yesterday. works great. one thing though...have you heard of a problem between the blackbird and the iva-w200 where the first two words of the voice prompt gets cut off? everytime the girl chimes in with a turn it starts with "a head" instead of "right turn a head" sounded funny at first, but nows its down right annoying!!
Old Feb 1, 2009 | 10:33 AM
WolfPack's Avatar
Ive been looking at doing this in my blazer...subscribed
Looks like a great start..I cant wait to see the outer shell come together.
Old Feb 1, 2009 | 10:42 AM
not sure I would double check all settings on both units (I doubt alpine would let an issue like that go without offering an update for the blackbird or something). I would call alpine tech support tomorrow morning for a quick and easy answer.
Old Feb 1, 2009 | 10:44 AM
Disco Dave's Avatar
thats what i had figured too. checked all the settings. i'll give them a call tomorrow. hopefully they can help! I do appreciate the recommendation to go with this though, what a great setup...super happy with it
Old Feb 2, 2009 | 01:29 PM
http://img379.imageshack.us/my.php?image=1004967um7.jpg
I applied 2 more layers to one side of the box so far today, I will most likely try to get 2 layers on all the sides today however I have to give about 1.5 hours curing time between sides. now when I say sides I mean (from the inside) the back which it is lying on, the walls on each side, the very botom, and between each side and the bottom. There are quite a few air bubbles, which it is a good idea to get out, however since I am just doing this to save some room and am not planning on competing with this box, I am cutting a few corners and just building it a little thicker. I will try to get some pics of it propped up on a few of the other sides for you guys later today.
Old Feb 3, 2009 | 07:16 PM
ok guys got a bunch done today will mention a bit on each picture
http://img6.imageshack.us/my.php?ima...psupporqh1.jpg
trimmed the box down and put in the top support to make the top of the box flush with the other panel.
http://img23.imageshack.us/my.php?im...intruckxo4.jpg
trimmed in the truck
http://img23.imageshack.us/my.php?im...erringsze9.jpg
my 2 speaker rings (one the sub mounts too, the other the sub will be recessed down inside of. see next image)
http://img127.imageshack.us/my.php?i...ogetherox1.jpg
the rings together
http://img127.imageshack.us/my.php?i...gstandsyo3.jpg
the stands mounted to the rings (this will hold the rings in the air to form structure to the box)
Old Feb 3, 2009 | 07:22 PM
http://img264.imageshack.us/my.php?i...intruckfx0.jpg
here is the rings mounted in the mold (in the truck)
http://img293.imageshack.us/my.php?i...retchedmw6.jpg
the fleece stretched over the mold and rings
http://img24.imageshack.us/my.php?im...glassedii6.jpg
the fleece getting glassed (those small hands are my 13 year old daughter, I am letting her help me)
http://img156.imageshack.us/my.php?i...glassedsu2.jpg
the fleece all glassed
http://img156.imageshack.us/my.php?i...fromtoplm8.jpg
the fleece all glassed from the top (here you can see the "top" of the box where it will be flush with the top of the rear panel. won't be perfect but it will be close enough for me)
Old Feb 3, 2009 | 07:47 PM
WolfPack's Avatar
That doesn't look like there's any glass mat on the fleece? Is that how its supposed to be or is it just the pic? It looks like just resin and fleece to me
Old Feb 3, 2009 | 08:11 PM
yes you are absolutely correct, I will let that dry tonight and then apply about 4 layers of fiberglass matte (and cloth I am using both) I use fleece because it is thick and absorbs a lot of resin. that alone will be a good thick layer. I will alos cut out the middle and apply a nice coat of resin along the inside seams of the front and back sides of the box as well as reinforce my sub rings.
