Tom woods drive shaft unboxing
Old 10-25-2019, 06:06 PM
Carlos Man's Avatar
Default Tom woods drive shaft unboxing
Just received my new drive shaft from Tom Woods which was ordered through lucky 8.
Considering I researched around for this item and came up short I figured I’d at least get some pictures up for you all.
I have to say so far I’ve very impressed with the over all look and details. This thing feels like a medieval weapon!
Ill post install photos later.
And apparently it uses all original bolts, I ordered some new ones from Lucky8 just Incase i mess one up. They were extremely helpful.
abran (10-29-2019)
Old 10-25-2019, 07:08 PM
Red5's Avatar
Nice. I love it when the zerks are on the end caps instead of buried down on the cross.
JUKE179r (10-28-2019)
Old 10-26-2019, 01:15 AM
Carlos Man's Avatar
Default Difficulty level 2 out of 10
This job took about 2 hours mostly because of the cramped space and having to use a vise grip and wrench for most of the job.
i soaked the bolts in break free for about two days prior to the job
i loosened all bolts with a breaker bar and wrench (go very slow when loosening) you can’t rush this you’ll strip the bolts.
make sure your car is in park and the Ebrake is set and your front tires are floating.
youll have to put the car in neutral and take the Ebrake off a couple times to turn the shaft.
it’s a very easy plug and play job.... make sure to tighten the bolts twice as tightening every bolt will slightly loosen the last.
Lifted from the axel
Tools needed
Your most important tools
You’ll need this combo for the bad angled bolts and installing the new shaft
Some bolts can be removed with your power tool but not all Remember to loosened all the bolts first.
Leave the bolts in until you finish the back end
The backend bolts will not come out and that’s okay
Remove and lay the front end down.
Take a long screw driver and using the vehicles frame for leverage pop the back end loose... very minimal force was needed
The following 3 users liked this post by Carlos Man:
enb54 (10-26-2019), JUKE179r (10-28-2019), whowa004 (10-28-2019)
Old 10-26-2019, 07:05 PM
Does it vibrate when you test drive it ?? I had 2 that were out of balance
Old 10-26-2019, 07:27 PM
Carlos Man's Avatar
nope so far so good ... no complaints yet
Old 10-27-2019, 07:08 PM
Carlos Man's Avatar
Drove about 50 highway miles on it and still no complaints.
I rate it 10/10
Old 10-27-2019, 08:39 PM
ZGPhoto's Avatar
Good luck with it, have dealt with many unhappy buyers.
Old 10-27-2019, 09:20 PM
Carlos Man's Avatar
I guess I’ll have to keep checking on it from time to time... I’ve never heard anything bad about them... what are some of the complaints so that I can monitor them.
Old 10-27-2019, 10:06 PM
Received 1,509 Likes on 1,236 Posts
I would be more concerned if I was Land Rover Corporate with someone spamming enthusiast sites claiming to be a member of the Land Rover Sales UK team
Old 10-28-2019, 10:20 PM
ZGPhoto's Avatar
Premature failure, just make sure to grease it every oil change
Quick Reply: Tom woods drive shaft unboxing
