Tools to change tranny fluid
Old Jan 3, 2009 | 10:23 AM
jw928's Avatar
Default Tools to change tranny fluid
Its about 20 degrees here and I would like to minimize crawling under the truck in the snow.
Does anyone know exactly what tools I need to change the transmission fluid? I think I read that its an 8mm allen key for the refill plug, but of course, my set only goes to 7mm.
Thanks,
John
'02 Disco 114k miles
Old Jan 3, 2009 | 11:00 AM
Default RE: Tools to change tranny fluid
Well, you don't have to change the filter so it is the drain plug only and I can't remember the size allen wrench to use, Sorry.
Old Jan 3, 2009 | 12:24 PM
jkid's Avatar
8mm is awfully big, that could be the drain plug though. Pretty sure the fill plug is smaller, like 5mm or so.
Old Jan 3, 2009 | 01:57 PM
JBEGIN's Avatar
im ready to go outside and have a look at my tranny fluid level.
so im looking for a allen plug ( on the side of the tranny?) then what? oh engine running, right?
Mike give me a walkthrough on this, buddy
Old Jan 3, 2009 | 10:48 PM
SDinDS's Avatar
ORIGINAL: Disco Mike
Why don't you have to change the filter??
Old Jan 3, 2009 | 11:03 PM
The transmission filter was supposed to be changed at 30,000 miles and then supposedly it never needs to be changed again.
I question the never again. That is what Land Rover says, but I still question it.
It never hurts to change a filter.
Old Jan 3, 2009 | 11:31 PM
SDinDS's Avatar
http://www.roverparts.com/Parts/9240.cfm
$60. I think it's worth it. Why take a chance?
They say fluid and filter every 30kmi
Old Jan 4, 2009 | 07:49 AM
unimoged's Avatar
Below is the procedure for changing the fluid, per alldata:
Automatic Gearbox
Service Repair No - N/A
Drain
[*]Ensure the gearbox is cool. Apply hand brake and securely chock front and rear wheels.[*]Place a suitable container beneath gearbox.[*]Clean area around oil filler/level and drain plugs.[*]Remove oil drain plug, remove and discard sealing washer.[*]Allow oil to drain.[*]Fit new sealing washer to oil drain plug.[*]Fit automatic gearbox drain plug and tighten to 15 Nm (11 lbs.ft) .[*]Remove oil filler/level plug, remove and discard sealing washer. Refill[*]Fill gearbox with recommended oil to bottom of oil level/filler plug hole.[*]Select 'P' (Park).[*]Ensure hand brake is applied.[*]Start engine and allow it to idle.[*]Apply foot brake.[*]Move selector lever through all gear positions, while continuing to fill gearbox. Select 'P' (Park).[*]With engine idling, continue filling gearbox until a 2mm bead of oil runs from oil filler/level plug hole.[*]Fit new sealing washer to automatic gearbox filler/level plug, fit plug and tighten to 30 Nm (22 lbs.ft) .[*]Stop engine.[*]Remove all traces of oil from gearbox casing.
[/ol]
Old Jan 4, 2009 | 05:51 PM
jw928's Avatar
Just to update the question, (there are far too many threads that never really get the answer posted).
It turns out that it was indeed an 8mm allen key for the fill plug and a 5mm for the drain.
I had planned on using a hand pump to get the fluid in. Unfortunately, it was about 15 degrees outside and the pump I was using worked fine on the first bottle, but then the hoses turned to stone, spilled the next bottle and then the hose came out of the transmission and sprayed me in the face.
After panicking that I wasn't going to be able to refill the fluid, I finally figured out that the tip on the Lucas additive was the same size as the transmission fluid bottles so I just screwed on the tip and was able to simply pour the fluid in without any trouble. (I wish I had tried that first).
Old Jan 4, 2009 | 06:40 PM
unimoged's Avatar
JW928,
I have always used is a medium size funnel, a 3 ft / 7/16" ID rubber hose that I placed on the end of the funnel.
I would run the hose down from the engine compartment to the transmission fill hole.
Gravity is a blessing in auto repair.
1998DiscoverySE
Jul 20, 2012 08:02 PM
collin Barrows
Aug 28, 2011 07:13 AM
LRScott
Mar 4, 2009 08:39 AM
freeland02
Engine & Internal
Nov 25, 2007 04:44 PM
freeland02
Freelander
Sep 27, 2007 10:15 PM
