Tools and Equipment I Carry Full TIme
Old Feb 4, 2018 | 01:14 PM
  #21
Sixpack577's Avatar
I've been carrying a swiss army knife since I was 7, and have seen all the original episodes of McGyver.
So I'm good.
Old Feb 4, 2018 | 02:03 PM
  #22
Alex_M's Avatar
Honestly, never been a huge fan of the swiss army knife. Almost does a lot of things, but doesn't really do anything that well. I'd assume have a stand alone knife, led flashlight, and maybe a small set of folding pliers for the keychain sometimes.
MacGyver is a must, though. With MacGyver you can do anything.
Old Feb 4, 2018 | 03:04 PM
  #23
OverRover's Avatar
All you need is The MacGyver Multitool!!!!
Old Feb 4, 2018 | 05:24 PM
  #24
number9's Avatar
Describes many mechs I've met well.
Old Feb 4, 2018 | 11:26 PM
  #25
OffroadFrance's Avatar
X1 ................. too true!
Alex, have you considered the amount of additional gas the 'on board weight' is costing you, it's like hauling around a couple of fatties everywhere. I always ask myself, "how often do I use this equipment" if the answer is rarely or never then it's left behind in the garage. In France you pay in with your auto insurance for a tow truck, they charge for it whether you like it or not, so now I just call the allocated insurance tow truck if I ever break down en route.
Old Feb 5, 2018 | 12:37 AM
  #26
Alex_M's Avatar
I have, but the fact of the matter is that I use pretty much all of it.
And honestly, the change in gas mileage has been negligible. I've driven her on tires that we're 20# lighter, each, with the back seats removed, and almost no tools. There was no calculable MPG change that I could see.
Blew my mind considering how huge the difference is after losing a couple serp belt accessories, but alas it seems to be the case.
Old Feb 6, 2018 | 05:08 PM
  #27
Hi Alex, only you know best what gear you need and what ventures you undertake when wheeling, I am suggesting from the sidelines and often highway trekking so my comment is probably a bit naive.
Old Feb 6, 2018 | 05:54 PM
  #28
Alex_M's Avatar
All good, brother. I do a fair bit of highway trekking as well and surprisingly there was no difference there either.
​​​​​​Also of course, everyone's needs are different. Any and all suggestions are welcome and appreciated. There's always something to learn or something that could have been overlooked and I appreciate the insight.
Old Feb 7, 2018 | 01:01 AM
  #29
Richard Gallant's Avatar
I found in my short time with these trucks my fuel mileage is pretty consistent, empty or loaded.
I keep a pretty full set of tools, a few spares and basic recovery gear on board all the time.
That would be ideal but I like to be as far from the civilized world as I can get, and no tow truck here is coming 6 hours up an Forest service road unless you pay a significant amount of money.
Which why I keep my off road vehicles in as good shape as I can. So far I have had no failures that stopped me getting home , 7 years in and R50 Pathfinder and 3 in an Xterra prior to that. I could either fix it or limp out.
Only 6 months in the Disco but, one 2 day trip and a several single day trips on some pretty interesting forest service roads in the snow and she has held well and performed solidly.
Old Feb 15, 2019 | 06:16 PM
  #30
No Doubt's Avatar
Jump Box w/ tire inflator to solve dead battery and low tire issues
Fix-A-Flat to solve some flat tire issues
OEM spare tire, lug, and sockets to solve other flat tire issues
5 Gallon Jerry can to solve out-of-fuel and emergency fire-starting issues
Duct tape to solve hose leak and misc issues
1 qt ATF fluid for ps steering and tranny issues
1 qt oil though I can't imagine 1 qt being a difference maker
1 wrench and spare serp belt in case of belt failure
1 philips/flat blade screwdriver
1 vise grips
1 industrial tow strap
2 flat wood blocks and 2 ratchet straps so that I can make 1 tire have grip in deep mud
1 emergency sleeping bag/poncho
some spare water for me or coolant
some trail mix "just in case"
Thinking about adding:
K-Seal in case of an emergency situation needing a temp solution for headgasket or cracked block
CPS in case I need to crawl under and refit to get going again
" " same for spare Rotoflex
black electrical tape
