Torque converter noise in reverse.
Strange sound from torque converter in reverse. Only when torque converter is slipping like reversing ups hill, or reversing with moderate speed.
Happened ever since I had t case installed.
Since I have no knowledge of transmissions t cases or torque converters. Does this mean anything other than the world will end on 12/21/12
Should'nt be the torque convertor cause it always turns in the same direction no matter what gear you are in.
Any fault code numbers, when was t=it last serviced and has the front drive shaft been rebuilt or replaced?
I guess I should explain the sound better, it's almost like the whine of gears coming together or slightly binding. It's Definatly more of a whine. I guess I fit ain't broke..
I don't remember it doing this with the old T case. Though the old one had a BAD bearring.
