Torque converter noise in reverse.
Old Dec 12, 2012 | 08:11 PM
Rover De Land's Avatar
Default Torque converter noise in reverse.
Strange sound from torque converter in reverse. Only when torque converter is slipping like reversing ups hill, or reversing with moderate speed.
Happened ever since I had t case installed.
Since I have no knowledge of transmissions t cases or torque converters. Does this mean anything other than the world will end on 12/21/12
Old Dec 13, 2012 | 10:34 AM
Should'nt be the torque convertor cause it always turns in the same direction no matter what gear you are in.
Any fault code numbers, when was t=it last serviced and has the front drive shaft been rebuilt or replaced?
Old Dec 13, 2012 | 04:51 PM
No faults, new front drive shaft
Old Dec 13, 2012 | 05:08 PM
How about a broken motor mount especially on the drivers side.
Old Dec 13, 2012 | 07:34 PM
I like that one, or you could PM the ever elusive but recently discovered Higgs Bosun
Old Dec 13, 2012 | 07:48 PM
I guess I should explain the sound better, it's almost like the whine of gears coming together or slightly binding. It's Definatly more of a whine. I guess I fit ain't broke..
I don't remember it doing this with the old T case. Though the old one had a BAD bearring.
Engnur
Aug 30, 2009 05:12 PM
LRScott
Mar 6, 2009 11:42 PM
sailorcolin
Apr 17, 2008 08:21 PM
kraelo
Apr 1, 2008 12:02 AM
jared
Dec 20, 2007 06:51 AM
