Torque Converter Solenoid Location
Guys, my automatic transmission from my 2004 D2 started slipping after an oil and filter change, I also occasionally have the M+S lights come on. I'm getting P0741 codes every other day. I bought an XYZ Switch and TC Solenoid. Through some of the posts here I now know where the XYZ is located however I cannot find the location for the TC Solenoid. Can you please share some wisdom here?
Thank you very much.
Received 1,189 Likes
on
glopez2k (08-27-2020)
Also check your battery voltage.
There are 18 ''official'' reasons for flashing M+S warnings, 15 of them are together with limp mode, 2 with no apparent effect and 1 which will let it operate only in economy mode... low battery power and XYZ switch are the most common.
I checked the RAVE manual and couldn't find a torque convertor solenoid.
Based on some google searching it looks like THT000010 is located in the trans and the pan has to come off for access. Here's a diagram showing it as item 3. If you hover over the little I next to the part description to the right you'll see it called out.
https://varuosad.alvadi.ee/en/vin/SA...cturer/74/4001
glopez2k (08-26-2020)
dconnor
01-27-2017 07:34 PM
